ProjeQtOr free project management software - [SOLVED] ProjeQtor automatically goes to upgradation - ProjeQtOr
30 Nov 2023 09:13 #1 by maitreyp
Since past 15 days, the ProjeQtor automatically goes into the upgrade mode. I was using the version 11.0.1 and it went to the 11.0.2 version when I tried to login. Following are the precise events:
  1. ProjeQtor login page was showing an upgrade is in process and only admin can login.
  2. No other user could login as the upgradation was in process. More than that, the application was showing the status as "open" and still no one was able to login.
  3. The cronjob automatically stopped.
  4. I have projeQtor installed on a local system and the system is not attached to the internet.
  5. On another instance it was also downgrading the current 11.0.2 to 11.0.1 out of the expectations.
30 Nov 2023 09:36 #2 by Arkhanje
Well your admin must have made updates, it doesn't matter in which direction, but it is normal that when an update is made, then no other user besides him can connect.
30 Nov 2023 12:03 #3 by maitreyp
The main issue is upgrades and downgrades happening automatically. It never happened before. It started suddenly and now it happens everyday.
01 Dec 2023 09:28 #4 by Arkhanje
Has your administrator installed the instal auto plugin ? Because without administrator or plugin intervention there is no native functionality in projeqtor to update your version
05 Dec 2023 09:22 #5 by maitreyp
No, we didn't have installed any auto update plugin into the projeQtor.
05 Dec 2023 10:52 #6 by babynus
Sure someone updated code of Projeqtor.
For instance, unzippped new code to replace old (this is the default migration process)
ProjeQtOr has no system thet changes code without a user action.
Even our Install Auto plugin requires an action of the admlinistrator to trigger the migration.
Moreover, this process requires internet access... If your server has no access to internet, it is impossible to troger migration other than replacing the code.
