ProjeQtOr free project management software - Export to MS-Project XML reverts low/high activities priorities - ProjeQtOr
23 Nov 2023 09:21 - 23 Nov 2023 10:38 #1 by brasal
ProjeQtOr use priorities from 999 (lowest) to 1 (highest) while MS-Project is reverse: 0 (lowest) to 1000 (highest). ProjeQtOr export to MS-Project XML keeps ProjeQtOr priority definition instead of translating it to MS-Project one.
Expected behaviour is :
  • ProjeQtOr priority 1 becomes MS-Project priority 1000, or probably preferably 999
  • ProjeQtOr priority 999 becomes MS-Project priority 0, or probably preferably 1
Last edit: 23 Nov 2023 10:38 by brasal.
23 Nov 2023 10:34 - 23 Nov 2023 10:37 #2 by Arkhanje
Last edit: 23 Nov 2023 10:37 by Arkhanje.
23 Nov 2023 15:50 #3 by brasal
Workaround :
* Copy the *priority* column in a spreadsheet
* Add a column with formula to reverse the priority : B2 = 1000 - A2
* Propagate for all lines
* Copy past the resulting column in MS-Project
The following user(s) said Thank You: Arkhanje
