ProjeQtOr free project management software - WBS and sub-project issue with profile and access to data - ProjeQtOr
10 Nov 2023 20:33 - 10 Nov 2023 21:21 #1 by ymn76ymn
File Attachment:
File Name: 01Wbsandsu...reen.zip
File Size:880 KB
File Attachment:
File Size:880 KB
For every project that I selected in the Projects screen, I notice that the same project appears in the sub-project field (in the Details screen) and when I make any modifications and save them, the project appears as a sub-project for another project, For example (wbs-5 of Project-five becomes sub-project within wbs-1.1)This problem appeared to me with all profile (administrator Supervisor, Project Leader, Project Member, …) and with some Access to data (reader, reader , updater, updater ) but with (creator, Creator , manager, Manager ) it is ok without issues.My Version:Projeqtor V11.0.1 Projeqtor V11.0.2 Google Chrome V119.0.6045.124_X64
Last edit: 10 Nov 2023 21:21 by ymn76ymn. Reason: for attachment files
11 Nov 2023 15:43 #2 by ymn76ymn
To correct the previous message: with (Creator, Creator+ , Manager, Manager+  it is ok without issue).
for complete the previous message:Or when I clear the data of sub project field and save updates the wbs-2 of project-two becames the last one (wbs-6).
13 Nov 2023 09:58 - 13 Nov 2023 09:58 #3 by Arkhanje
Good morning,
For WBS problems, you can do a consistency check to be sure that everything is ok in administration screen.
Then the "is under project" field was personalized on your session and was made mandatory, was the personalization in the screen customization plugin carried out as you wanted?
Last edit: 13 Nov 2023 09:58 by Arkhanje.
The following user(s) said Thank You: ymn76ymn
13 Nov 2023 17:48 #4 by ymn76ymn
thank for reply,
I don't have Customization of screens plugin,
no issue found in administration screen when i did consistency check,
the most important thing to me is the wbs and sub-project issue with project member profile and access to data (update+).
14 Nov 2023 09:01 #5 by Arkhanje
Hello !
This is surprising because this field is not obligatory. Yours yes.
14 Nov 2023 19:50 #6 by ymn76ymn
Thank for reply,
The field of sub-project populated automatically without selecting any project to be as sub-project, this problem appear with a project member profile or any profile and access to data with(updater+, reader+),
I hope that you have a solution.
Best regards.
