ProjeQtOr free project management software - Mailing doesn't work with SMTP realy without authentification - ProjeQtOr
10 Nov 2023 17:14 - 11 Nov 2023 14:24 #1 by jmmbb
i'm using SMTP relay between two secured zones.
Rules are simple : every mail adressed to second zone (This email address is being protected from spambots. You need JavaScript enabled to view it.) are relayed.
So, authentification is not required, only smtp server adress and port.
Via telnet, it work fine but, when configuring PHPMailer via Projeqtor, errors occurs with "Connection failed, error #2 unable to connect".
It seems that phpmailer try to make authenticated connection but, without login and password, it can go...
Last edit: 11 Nov 2023 14:24 by jmmbb.
10 Nov 2023 17:18 #2 by jmmbb
Also noticed that changing log level in projeqtor doesn't seems to change log level in phpmailer (need to add a line phpmailer->SMTPDebug=4; in sendmail()
10 Nov 2023 17:45 #3 by jmmbb
In reading code, it seems that no user and password make automaticaly a call to standard php mail so need to configure sendmail.
Perhaps you can correct it or be more clear in config screen (no user and no password -> use sendmail).
14 Nov 2023 00:32 #4 by babynus
We'll have a look at this
17 Nov 2023 15:00 - 17 Nov 2023 15:02 #5 by jmmbb
I confirm that with a simple sending script via PHPMailer using
$PHPMailer->isSMTP();
$PHPMailer->SMTPAuth=false;
the email is correctly sent and received successfully on client side. When the same information is provided to ProjeQtOr, the email is submitted to SendMail (in my case, this is not suitable, and in the general context, the options specify "PHPMailer in SMTP mode on port 25," which does not match the observed behavior.
Last edit: 17 Nov 2023 15:02 by jmmbb.
18 Nov 2023 17:26 #6 by babynus
Ticket #7711 recorded
