ProjeQtOr free project management software - Problem about Copy project - Page 2 - ProjeQtOr
11 Feb 2012 20:27 #7 by babynus
Fixed.
Thanks gerg35. You were almost there, and your analysis was correct.
To fix completely :
- sort array $activities before copying (then copy is in the good order), but sort must preserve keys (use uasort)
- then same issue with milestones : as they are copied after activities, order is not correct (they are alway after activities) : I had to implement array of object that can be of different classes, and adapt sort functionality.
Then it works !
13 Feb 2012 11:39 #8 by chris35
Hi Babynus,
I get the v2.0.1 snapshot from the svn repository to test your fix.
When I copy a project, the following error is occured:
Erreur sur finalizeMessageDisplay('resultDiv') :
La destination n'est pas un 'node' ou pas un 'widget'
ou lastOperation or lastOperationStatus n'est pas un 'node'.
Fatal error: Maximum execution time of 30 seconds exceeded in C:\projets\projector\V2.0\projector\model\persistence\Sql.php on line 171
Contactez votre administrateur.
My template project have:
- 34 activities, not assigned to resources
- 4 milestones
Where can I configure the timeout to increase the value?
It seems to be a little long time to take more than 30 seconds to copy the project, what do you think about?
13 Feb 2012 18:54 #9 by babynus
in php.ini,
max_execution_time = 300
or in the php code, for instance in copyProjctTo.php
set_time_limit(300);
Yes, it seems quite long... but all depends on your server capacity.
I should have a try...
