ProjeQtOr free project management software - project pdf - ProjeQtOr
project pdf
07 Feb 2012 11:13 #1 by ekolossov
project pdf was created by ekolossov
from planning (Gantt chart) click "export to pdf" and pdf will be genarated but... not for the full project but only for the first 3 weeks of the project independently what is on screen. Looking like the length is Ok - it producing more than one page but width is limited to first 3 weeks...
This is very omportant because project snapshot required for certification prrocess...
07 Feb 2012 13:24 #2 by babynus
Replied by babynus on topic RE : project pdf
This is a know issue.
First attempts to fix it failed...
It' due to library used to export to pdf, html2pdf, which doe not tacke into account tables larger than page.
If anyone has an idea for a fixing ...
Workarounds :
1) change the scale so that you will see a larger period
2) export first preriod, then change start date and export second period, and so on.
07 Feb 2012 13:40 #3 by ekolossov
Replied by ekolossov on topic RE : project pdf
you can try www.fpdf.org /
07 Feb 2012 13:48 #4 by babynus
FPDF is just a library to code PDF files.
The advantage of html2pdf is that it automatically converts html pages to pdf files.
This has been used to automatically convert all printable reports (in html) to exportable reports (in pdf) witthout much work.
Now the question is : should it be insteresting to redevelop the PDF export of gantt ?
Maybe, as it will set possible to export full planning, and possibly improve generation performance (tranformation performance from complex html to pdf is very poor).
But this is a very heavy job...
07 Feb 2012 13:53 #5 by ekolossov
this one: www.web2pdfconvert.com /
converting multiple pages without problem
