ProjeQtOr free project management software - ProjeQtOr performance issue : too slow... - ProjeQtOr
27 Sep 2023 12:24 #1 by iFlorian
I have a performance issue with ProjeQtOr.
For example, when I want to move a task on a small project, it's very slow on my instance instead of projeqtor's online demo.
For example, on my instance it's take 30655ms on ProjeQtOr online demo : this same action take 153ms !
How can I improve that ?
I'm on ProjeQtOr V11, PostgreSQL 16, PHP 8.2, Apache2.4
Server (I have put Postgresql on the same server) : debian 12 with 4 CPUs,  Intel(R) Xeon(R) Gold 6234 CPU @ 3.30GHz, 12go RAM
Thanks for help,
Florian
“Be a yardstick of quality. Some people aren't used to an environment where excellence is expected.” ~ Steve Jobs
"...and while some may see them as the crazy ones, we see genius, because the ones who are crazy enough to think that they can change the world, are the ones who do." ~ Think Different
29 Sep 2023 12:39 #2 by iFlorian
Does anyone have the same problem with postgresql?
Is ProjeQtOr performance supposed to be the same between a mysql and a postgresql database?
Or is there a slowdown with PostgreSQL?
Is PostgreSQL still maintained by ProjeQtOr?
Thank you in advance for your answers.
Best regards,
29 Sep 2023 16:52 #3 by iFlorian
For example,
In order to move up or move down a task in the planning composed of 5 tasks, it's take between 10 and 15 secondes minimum ! Sometimes more...
29 Sep 2023 17:19 #4 by babynus
Difficult to analyse performance issue that are not produced on demo.
Best way will be for you to insert some "debugLog()" into the code to trace what happens.
29 Sep 2023 17:20 - 29 Sep 2023 17:21 #5 by babynus
As long as I know, there is not performance issue with PostgreSql.
Compared to MySql, I find it a bit slower on single tasks, but better on high volumetrics or high load, but is is in a small part only, never 30x slower.
Last edit: 29 Sep 2023 17:21 by babynus.
