ProjeQtOr free project management software - [SOLVED] error on creating simulation base - ProjeQtOr
22 Jun 2023 11:34 #1 by pdecloedt
when i try to create a simulation base cron stopped and it is writing on log file :
2023-06-22 11:30:15.772 ===== TRACE ===== Début de suppression d'un environnement de simulation - base test
2023-06-22 11:30:15.772 ***** ERROR ***** [V10.4.1] EXCEPTION *****
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] on file '/var/www/html/projeqtor/model/DataCloning.php' at line (1003)
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] cause = Call to a member function exec() on null
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] => #0 /var/www/html/projeqtor/tool/cronExecutionStandard.php (157) -> deleteDataCloning()
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] => #1 /var/www/html/projeqtor/model/Cron.php (547) -> dataCloningCheckRequest()
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] => #2 /var/www/html/projeqtor/tool/cronRun.php (39) -> run()
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] Call to a member function exec() on null
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] Exception while executing CRON script : fix the source issue and manually restart the CRON Process
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] === Trace Stack for last error ===
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] => /var/www/html/projeqtor/tool/projeqtor.php at line 1553 calling debugPrintTraceStack()
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] => calling exceptionHandler()
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] CRON abnormally stopped
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] => /var/www/html/projeqtor/model/Cron.php at line 308 calling debugPrintTraceStack()
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] => /var/www/html/projeqtor/tool/cronRun.php at line 35 calling Cron:abort()
2023-06-22 11:30:15.773 ***** ERROR ***** [V10.4.1] => calling cronAbort()
22 Jun 2023 11:56 #2 by babynus
Strange, as Cron displays error about Deleting an environment....
Maybe you (or another user) requested for the deletion of an environment.
It seems this delete request refers to non existing DB...
Please check the deletion request in progress, purge thoose that are not valide (DB does not exist any more) and try again.
22 Jun 2023 11:58 #3 by pdecloedt
how can I purge it ?
23 Jun 2023 09:51 #4 by babynus
dete corresponding line from table datacloning
DELETE FROM datacloning WHERE isRequestedDelete=1
