ProjeQtOr free project management software - [SOLVED] Can't fix an issue - ProjeQtOr
07 Jun 2023 07:57 #1 by Bena
Can't fix an issue was created by Bena
This issue is not fixed when I try to fix it using the "Fix issue" button in the Administration page.
Best regards.
Bena
09 Jun 2023 16:33 #2 by babynus
Replied by babynus on topic Can't fix an issue
Just try and move the project (#139)
It is first on parent's list, move it as second, then back to first.
Issue should be fixed
The following user(s) said Thank You: Bena
11 Jun 2023 23:46 #3 by Bena
Replied by Bena on topic Can't fix an issue
Thanks, in fact, it was the project created by the HR module. I remove the module and then it works :)
Bena
12 Jun 2023 11:46 #4 by babynus
I guess you're using an old version, as on latest versions, we forced WBS of Leave Project to 0
