ProjeQtOr free project management software - [SOLVED] "Validation imputation" - ProjeQtOr
31 Mar 2023 12:05 #1 by loicr
Since last update when ressources entering their time in "imputation" they don't have green box "imputation saved", it always gray and write "no imputation modification" but datas are saved, i can see tem in CSV export.
Nothing is taken into account in project / activities and planning ...
If i go myself with admin right and clic save without modifications .... it say "green box "imputation saved"" and datas are taken into account on all planning.
Thanks for your support cause, it is really dangerous.
LR
ps: Nothing written in log.
31 Mar 2023 12:25 #2 by alainforma
Replied by alainforma on topic "Validation imputation"
HI,
From wich version to wich version do you migrate ?
Have you checked profil's right on timesheet screen?
Have you check that project are not locked by month on consolidation screen ?
31 Mar 2023 14:00 #3 by loicr
Replied by loicr on topic "Validation imputation"
We have made migration from 10.2.X to 10.3.0 and 10.3.1 in same day
no monthly consilidation activated
right ... unable to find where we could have change something.
31 Mar 2023 16:17 #4 by loicr
According to our tests in // on our prod & test base the situation seems to be the following:
we did an ubuntu 22 update on our prod database which updated PHP extensions and others yesterday ...
by doing the Ubuntu update on our test database (working before), the malfunction observed on our prod database has just occurred on our test database ...
We are in the restoration phase before Ubuntu update ... to be continued on Monday!
03 Apr 2023 08:30 #5 by loicr
problem still present.
I'll try to go back in 10.2...
03 Apr 2023 09:33 #6 by Arkhanje
Replied by Arkhanje on topic "Validation imputation"
hello
After testing, we do not reproduce. The filling of times is done correctly for all resources and all profiles. The green box is always displayed with the backup message and everything is taken into account in the planning.
You say: Nothing written in the journal.
which? Those of ProjeQtOr? In this case, also look at the logs of the browser which could perhaps help us.
Have you tested the same manipulations on our demo database?
