ProjeQtOr free project management software - [SOLVED] Project: Linked Elements are always empty - ProjeQtOr
30 Mar 2023 15:44 #1 by TimoHocker
I have noticed that the list of linked elements in the Project view is always empty. Tickets or Change requests display that list without an issue.
As an example I have linked a Ticket to a project. In the Ticket the link is visible, but in the Project it only shows the link counter (1).
30 Mar 2023 15:59 #2 by Gautier
What Projeqtor version are you using ?
30 Mar 2023 16:00 #3 by TimoHocker
ProjeQtOr V10.2.3 (328)
PHP 8.1.17
30 Mar 2023 17:50 #4 by babynus
If you used Screen Customization plugin, you may face an old issue of this plugin.
Install the latest version of the plugin and access the Customization form for object Project to fix the issue.
31 Mar 2023 13:21 #5 by TimoHocker
After updating ScreenCustomization to 6.6 and letting it fix all the warning messages, the links are showing up again. Thank you.
