ProjeQtOr free project management software - Projector v2.0.0 installation error - ProjeQtOr
06 Feb 2012 08:00 #1 by syncro
When installing projector v2.0.0, i get the following message:
ERROR : Impossible to load class BreadCrumbStack
=> Not found in ../model/BreadCrumbStack.php
=> Not found in ../model/persistence/BreadCrumbStack.php
Is the installation package complete (as these 2 files are not present)?
06 Feb 2012 08:56 #2 by babynus
The Class your server is looking for is not part of Project'Or RIA code.
It will never find it...
Infact, I faced this kind of issue : it is due to another application installed on your server, which left some trash cache on the server : stop your php server, empty the cache, restart.
It should work better then.
06 Feb 2012 09:45 #3 by syncro
Loading the application on Firefox solved the problem.
It was in fact the cache on Google Chrome (used initially) which caused the problem.
Thank you.
