ProjeQtOr free project management software - [SOLVED] Connexion OVH Imap for ticket failed - ProjeQtOr
27 Feb 2023 10:09 #1 by CZAM31
Good morning
I tried several configurations to connect an OVH IMAP account but none seem to work
(No answer that could help me on the forum or by OVH support)
I tried different config. but it doesn't work.
"{ssl0.ovh.net:993}Boîte de réception"
 "{ssl0.ovh.net:993}INBOX"
 "{ssl0.ovh.net:993}"
logs :
 [V10.2.2] ERROR *****
on file '/var/www/projeqtor/model/ImapMailbox.php' at line (86)
cause = imap_open(): Couldn't open stream {ssl0.ovh.net:993}INBOX
Error connecting to Mailbox {ssl0.ovh.net:993}INBOX for This email address is being protected from spambots. You need JavaScript enabled to view it.
[CLOSED] IMAP connection broken (server response)
Furthermore, it seems necessary to deactivate the cron to be able to make changes to the imap account: If the cron is active, and despite the recording of new values in the "IMAP Server" zone, the previous values return just after the execution of the cron as if nothing had been changed. (A test button might be useful too)
Thanks a lot for fixing this issue !
02 Mar 2023 09:11 - 02 Mar 2023 09:17 #2 by babynus
Try additional options in the IMAP url
{ssl0.ovh.net:993/novalidate-cert}INBOX
{ssl0.ovh.net:993/ssl/novalidate-cert}INBOX
{issl0.ovh.net:993/imap/ssl/novalidate-cert}INBOX
If none works, ask your provider expected options.
Last edit: 02 Mar 2023 09:17 by babynus.
02 Mar 2023 09:24 #3 by CZAM31
This configuration works
Thanks a lot !!!!
