ProjeQtOr free project management software - [SOLVED] Validation sheet => fill in by admin not working ? - ProjeQtOr
22 Feb 2023 11:41 #1 by LaurentC
If a standard user fills in his timesheet, it works well.
If the admin fills in the timesheet of a standard user, there is no submit button. It it possible to enter work for the 1st week and save it. But it is impossible to enter work for the following week.
Best regards
#L.
23 Feb 2023 10:11 #2 by Arkhanje
Hi
If the admin is filling out a standard user's timesheet, there is no submit button.
No actually. It's normal. Only users themselves can submit their work. On the other hand, you can validate the work without submitting it.
It is possible to enter the work of the 1st week and save it. But it is impossible to go into work for the following week.
This is probably because you have set a block for entering time in the future.
Global Parameters > timesheet or Specific Access > Monthly consolidation of projet
23 Feb 2023 10:50 #3 by LaurentC
Thanks for your reply,
But:
This is probably because you have set a block for entering time in the future. => I have the same concern with input time in the past
Global Parameters > timesheet or Specific Access > Monthly consolidation of projet => this option seems to have no effect on this concern.
It's like the admin can only fill in the timesheet form for only 1 week.
Best regards
24 Feb 2023 10:32 #4 by Arkhanje
May be the option but is it on the monthly consolidation screen, the previous month has not been blocked?
Otherwise it is also possible that the resource has already validated its week. Submission and validation block imputations
The following user(s) said Thank You: LaurentC
27 Feb 2023 09:40 #5 by LaurentC
No. This is still unclear.
As an admin, I want to input and validate some work of a resource. This should be possible.
For a week n, I can input and save his work (I don't validate).
Then, go to week n+1
Then go back to week n
It's no more possible to modifiy the inputs. => problem
Then, go again to week n+1. Impossible to input new work. => problem
These two issures may have the same root cause.
Log out / log in has no effect.
Best regards
02 Mar 2023 09:06 #6 by babynus
Which version are you using ?
Can you please post screenshots ?
