ProjeQtOr free project management software - [SOLVED] Installation problems - ProjeQtOr
22 Feb 2023 10:49 #1 by insaad
Bonjour,
Je n'arrive pas à installer l'application projeqtor sur mon environnement de test (vmware workstation)
- server window 2019
- Wampserver 3.3.0
- Je suis administrateur de mon poste
Tous les services sont bien lancés sur la vm.
J'ai respecté la procédure à la lettre mais lorsque j'arrive sur la page de configuration de l'application et que je remplis les champs, rien ne se passe après avoir cliqué sur "save configuration". La même page se recharge et je n'ai rien d'autre qui se passe sans aucun message d'erreur (voir PJ)
Je ne sais pas quoi faire et ai besoin de votre support.
Merci d'avance
22 Feb 2023 10:50 #2 by Plucks
Replied by Plucks on topic Problème d'installation
Please respect forum rules, write your question in english.
The following user(s) said Thank You: insaad
22 Feb 2023 10:59 #3 by insaad
Replied by insaad on topic Problème d'installation
My bad, sorry.
Hi there
It's impossible for me to install projeQtor in my envionnement test:
- windows server 2019
- Wampserver 3.3.0
- I'm the local VM's administrator
All wamp services seems to be launched.
I respected the installation procedure (stack PHP/mysql), projeQtor is unzipped in the wamp server folder "www" and when i have the projeQtor configuration page in http://localhost/proQtor , when i click in "save configuration", the same page is loaded and i have no more reactions.
Do you have some advices for me ? Thanks a lot.
22 Feb 2023 12:08 #4 by insaad
Replied by insaad on topic Installation problems
i checked Apache, PHP and Mysql logs and no problems is loged
24 Feb 2023 11:35 #5 by babynus
Replied by babynus on topic Installation problems
Do you have a log file created where you defined projeqtor log file ?
Defaut location is ../files/logs
NB : check that php user (user that launches Apache) has write rights on whole projeqtor directory structure (at least the time to finish the configuration)
08 Mar 2023 10:50 #6 by insaad
it was a mistake... I just wanted to open ProjeQtor in the server. It's working in my client.
Thaks for the help Babynus :)
