ProjeQtOr free project management software - Affectation import issue - ProjeQtOr
02 Feb 2012 22:48 #1 by ThierrC49
Hello Babynus,
I'm trying to import affection to mass configuration, I have affected 1 user to 1 project, export it and by cut and past dupplicate affectation for all user I have.
in column "ou utilisateur" I have cut and past the user exported by user export
When I'm trying to import the new file the tool reject me by this :
Contrôles invalides.
le champ 'ressource ou contact ou utilisateur' est obligatoire
le champ 'projet' est obligatoire
Do you think Why?
Thierry,
03 Feb 2012 14:38 #2 by babynus
The issue is registered.
You can take a workaround : replace cations with ids for fields.
Yu will get available ids using the help button beside type of element to import.
