ProjeQtOr free project management software - Total revenue doesn't sum up correctly - ProjeQtOr
18 Feb 2023 20:40 #1 by pantunes
Hi all,
I noticed that the total revenue calculated for a project doesn't sum up correctly accordingly to the revenue of its subprojects.
I mean, when I check the revenue of the subprojects and calculate the sum, the total amount calculated doesn't equal the revenue of the main project these subprojects belong to.
This issue has appeared before but it solved by itself.
Though, it is now happening again and I don't know what to do to prevent it. The version installed is 10.2.2.
Thank you for your help!
18 Feb 2023 21:01 #2 by babynus
Issue known : closed sub-projects are not taken into account.
Issue fixed on V10.2.3.
The following user(s) said Thank You: pantunes
18 Feb 2023 21:03 - 18 Feb 2023 21:27 #3 by pantunes
Thank you for your reply!
I have no closed subprojects under this project. Should I assume it is the same issue you already identified?
Last edit: 18 Feb 2023 21:27 by pantunes.
