ProjeQtOr free project management software - [SOLVED] Material Resource - Screens Customization plug'in issus - ProjeQtOr
09 Feb 2023 15:32 #1 by bourle
In the "Screens Customization plug'in", I have this error when I choose "Material Resources".
"Some screen customizations are not consistent any more with current version :
- Material Resources
Screen customizations have been fixed automatically
Refresh this screen (reselect menu) as long as this message is displayed"
Some informations
- ProjeQtOr version : 10.2.2
- Plug-ins version : 6.5
- Windows 2016 IIS
- PHP 8.1
- MySQL
09 Feb 2023 20:08 #2 by babynus
Just do what the message says : refresh the screen (select again Screen Customization menu).
This will fix issues due to new fields on new versiobn.
After few times, issues will be fixed, and message will not be displayed any more.
The following user(s) said Thank You: bourle
10 Feb 2023 11:38 - 10 Feb 2023 11:39 #3 by bourle
I did it several times without the message disappearing. I changed the language from EN to FR (which implies a reconnection which is done automatically) and it works.
So I don't know what made it work:
- it was refreshed one last time which was enough
- to exit is to return to the screen
- change of language
But now, is OK.
Thank you
Last edit: 10 Feb 2023 11:39 by bourle.
