ProjeQtOr free project management software - [SOLVED] Screen customization: entanglement with user, employee and resource - ProjeQtOr
28 Nov 2022 17:42 #1 by bgenolini
With the 6.4 version of the screen customization plug-in, when I select "Employee", I actually customize the resource screen. And when I select "Resource", I get the user screen. Possibly because I am on the old 9.3.5 version of the app and working with the French language?
Best regards,
Bernard
29 Nov 2022 09:07 #2 by babynus
What makes you think of that switch ?
Note that User / Resource / Contact and Employee may look like each other as they use same db table.
12 Dec 2022 16:01 #3 by bgenolini
You're right. I have been trapped by those simlarities. Sorry for the inconvenience.
Anyway, this tool has been useful for us.
Bernard
