ProjeQtOr free project management software - [SOLVED] Screen Customization: Custom List does not work - ProjeQtOr
30 Sep 2022 16:47 - 30 Sep 2022 16:49 #1 by TimoHocker
After creating a custom list, the custom list screen does not open again and causes an error to be written on the server side.
The Plugin is on version 6.3
2022-09-30 16:06:42.294 ===== TRACE ===== =====================================
2022-09-30 16:06:42.294 ===== TRACE ===== PLUGIN SQL FILE : ../plugin/screenCustomization/temp.sql
2022-09-30 16:06:42.296 ===== TRACE =====  Table "question" altered.
2022-09-30 16:06:42.297 ===== TRACE =====
2022-09-30 16:06:42.297 ===== TRACE ===== DATABASE UPDATED
2022-09-30 16:06:42.297 ===== TRACE =====  WITH NO ERROR
2022-09-30 16:09:07.759 ***** ERROR ***** [V10.0.6] EXCEPTION *****
2022-09-30 16:09:07.759 ***** ERROR ***** [V10.0.6] on file '/var/www/html/projeqtor/model/custom/QuestionResolution.php' at line (31)
2022-09-30 16:09:07.759 ***** ERROR ***** [V10.0.6] cause = Class "PlgCustomList" not found
2022-09-30 16:09:07.759 ***** ERROR ***** [V10.0.6]    => #0 /var/www/html/projeqtor/tool/projeqtor.php (1777) -> require_once()
2022-09-30 16:09:07.759 ***** ERROR ***** [V10.0.6]    => #2 /var/www/html/projeqtor/model/persistence/SqlElement.php (8508) -> class_exists()
2022-09-30 16:09:07.759 ***** ERROR ***** [V10.0.6]    => #3 /var/www/html/projeqtor/plugin/screenCustomization/screenCustomizationFunctions.php (330) -> class_exists()
2022-09-30 16:09:07.759 ***** ERROR ***** [V10.0.6]    => #4 /var/www/html/projeqtor/plugin/screenCustomization/refreshCustomList.php (39) -> screenCustomisationGetCustomClassList()
Last edit: 30 Sep 2022 16:49 by TimoHocker.
01 Oct 2022 15:53 #2 by babynus
Check that file PlgCustomList.php exists in directory projeqtor/model/custom
If not : be sure that PHP user (www-data on deban/ubuntu) has complete write access on the whole structure of projeqtor file,
then reinstall the plugin.
05 Oct 2022 08:59 #3 by TimoHocker
The file did not exist. I assume it was the missing docker volume when I installed the plugin. After reinstalling the plugin, the custom list site opens again.
