ProjeQtOr free project management software - [SOLVED] Kanban settings are not saved between sessions - ProjeQtOr
26 Sep 2022 11:06 - 26 Sep 2022 11:09 #1 by TimoHocker
Creating a new post because the first one contained too many issues and wasn't receiving any more answers.
The settings in the top right of the kanban view are not getting saved. When I disable "show work on elements" it becomes enabled again once I log out and back in.
As stated in the previous post, an analysis on the database shows that the setting is written to the database, but seems to be ignored on loading.
TimoHocker post=33799 wrote: ...
I looked into the database to find where the parameters for kanban are stored, specifically the 'show work on elements'.
For my user it is stored in parameter with parametercode kanbanSeeWork8 and value null.
When I log in the checkbox is enabled and work is shown on all elements.
Changing the value of the checkbox correctly writes null or 1 into the database and updates the display, but it doesn't read the value on login.
Last edit: 26 Sep 2022 11:09 by TimoHocker. Reason: Quoting previous post
27 Sep 2022 11:34 #2 by babynus
Cannot reproduce. Works fine for me.
Can you try and reproduce on Demo (demo.projeqtor.org) ?
27 Sep 2022 12:47 #3 by TimoHocker
The demo correctly saves the settings.
I think the issue might be related to the database, because we are using postgresql instead of mysql.
I can send you a dump of the parameters table if that helps with analysis.
27 Sep 2022 15:59 #4 by babynus
Cannot reproduce, even on postgres.
Possibly you have some duplicates.
Try and delete parameters for given user
DELETE parameter where parameterCode like '%kanban%' and idUser=[yourid];
27 Sep 2022 16:11 #5 by TimoHocker
I successfully reset my settings with the mentioned command. The setting is still not saved after configuring it again.
I have noticed that the setting "show large elements" does save correctly, but it uses 'on', 'off' instead of null, 1. I have manually set "kanbanSeeWork8" to 'off' and it now loads without a problem.
The issue returns when I change the checkbox, then it writes 1 and null again.
01 Oct 2022 15:11 - 01 Oct 2022 15:11 #6 by babynus
We'll have a look.
(issue may depend on PHP version)
Last edit: 01 Oct 2022 15:11 by babynus.
