ProjeQtOr free project management software - Issue during Risk creation - ProjeQtOr
08 Sep 2022 19:22 #1 by matthieu.froment
After a 10.0.0 installation upgraded to 10.0.5, I have reactivated the Risk module and I am loggued with an admin account (I have check the admin has rights to create risks)
I cannot type a name in the corresponding field : always blank if the focus is in the field. The look&feel is also strange. Please see the screenshot.
When I look in the logs, I have this :
2022-09-08 19:12:09.524 ***** ERROR ***** [V10.0.5] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.risk' doesn't exist
2022-09-08 19:12:09.525 ***** ERROR ***** [V10.0.5] For query : select * from status where id in (select distinct idStatus from risk) order by sortOrder asc
2022-09-08 19:12:09.525 ***** ERROR ***** [V10.0.5] Strack trace :
2022-09-08 19:12:09.525 ***** ERROR ***** [V10.0.5] #0 Sql->query called at [/var/www/projeqtor/model/persistence/SqlElement.php:2913]
2022-09-08 19:12:09.525 ***** ERROR ***** [V10.0.5] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/projeqtor/model/persistence/SqlElement.php:8592]
2022-09-08 19:12:09.525 ***** ERROR ***** [V10.0.5] #2 SqlElement->getExistingStatus called at [/var/www/projeqtor/view/objectList.php:209]
2022-09-08 19:12:09.525 ***** ERROR ***** [V10.0.5] #3 include called at [/var/www/projeqtor/view/objectMain.php:119]
2022-09-08 19:12:09.526 ***** ERROR ***** [V10.0.5] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.risk' doesn't exist
2022-09-08 19:12:09.526 ***** ERROR ***** [V10.0.5] For query : select * from status where id in (select distinct idStatus from risk) order by sortOrder asc
2022-09-08 19:12:09.527 ***** ERROR ***** [V10.0.5] Strack trace :
2022-09-08 19:12:09.527 ***** ERROR ***** [V10.0.5] #0 Sql->query called at [/var/www/projeqtor/model/persistence/SqlElement.php:2913]
2022-09-08 19:12:09.527 ***** ERROR ***** [V10.0.5] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/projeqtor/model/persistence/SqlElement.php:8592]
2022-09-08 19:12:09.527 ***** ERROR ***** [V10.0.5] #2 SqlElement->getExistingStatus called at [/var/www/projeqtor/tool/displayQuickFilterList.php:83]
2022-09-08 19:12:09.527 ***** ERROR ***** [V10.0.5] #3 include called at [/var/www/projeqtor/view/objectList.php:1151]
2022-09-08 19:12:09.527 ***** ERROR ***** [V10.0.5] #4 include called at [/var/www/projeqtor/view/objectMain.php:119]
2022-09-08 19:12:10.434 ***** ERROR ***** [V10.0.5] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.risk' doesn't exist
2022-09-08 19:12:10.435 ***** ERROR ***** [V10.0.5] For query : select risk.id as id, T1.name as nameProject, T2.name as nameRiskType, risk.name as name, convert(concat(COALESCE(T3.sortOrder,''),'#split#',T3.name,'#split#',COALESCE(T3.color,'')) using utf8mb4) as colorNameSeverity, convert(concat(COALESCE(T4.sortOrder,''),'#split#',T4.name,'#split#',COALESCE(T4.color,'')) using utf8mb4) as colorNameLikelihood, convert(concat(COALESCE(T5.sortOrder,''),'#split#',T5.name,'#split#',COALESCE(T5.color,'')) using utf8mb4) as colorNameCriticality, convert(concat(COALESCE(T6.sortOrder,''),'#split#',T6.name,'#split#',COALESCE(T6.color,'')) using utf8mb4) as colorNameStatus, T7.fullName as nameResource, risk.idResource as idResource, convert(concat(COALESCE(T8.sortOrder,''),'#split#',T8.name,'#split#',COALESCE(T8.color,'')) using utf8mb4) as colorNamePriority, risk.actualEndDate as actualEndDate, risk.handled as handled, risk.done as done, risk.idle as idle,risk.idProject as idproject from risk left join project as T1 on risk.idProject = T1.id left join type as T2 on risk.idRiskType = T2.id left join severity as T3 on risk.idSeverity = T3.id left join likelihood as T4 on risk.idLikelihood = T4.id left join criticality as T5 on risk.idCriticality = T5.id left join status as T6 on risk.idStatus = T6.id left join resource as T7 on risk.idResource = T7.id left join priority as T8 on risk.idPriority = T8.id where risk.idle=0 and risk.idProject in (0, 4) and ( ((risk.idProject not in (0) or risk.idProject is null ) and (risk.idProject not in (0) or risk.idProject is null or (risk.idResource=1) ) and (risk.idProject not in (0) or risk.idProject is null or (risk.idUser=1) )) ) order by risk.id desc
2022-09-08 19:12:10.435 ***** ERROR ***** [V10.0.5] Strack trace :
2022-09-08 19:12:10.435 ***** ERROR ***** [V10.0.5] #0 Sql->query called at [/var/www/projeqtor/tool/jsonQuery.php:794]
2022-09-08 19:12:14.295 ***** ERROR ***** [V10.0.5] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.risk' doesn't exist
2022-09-08 19:12:14.295 ***** ERROR ***** [V10.0.5] For query : desc risk
2022-09-08 19:12:14.295 ***** ERROR ***** [V10.0.5] Strack trace :
2022-09-08 19:12:14.295 ***** ERROR ***** [V10.0.5] #0 Sql->query called at [/var/www/projeqtor/model/persistence/SqlElement.php:4097]
2022-09-08 19:12:14.295 ***** ERROR ***** [V10.0.5] #1 SqlElement->getFormatList called at [/var/www/projeqtor/model/persistence/SqlElement.php:3601]
2022-09-08 19:12:14.295 ***** ERROR ***** [V10.0.5] #2 SqlElement->getDataType called at [/var/www/projeqtor/view/objectDetail.php:1560]
2022-09-08 19:12:14.295 ***** ERROR ***** [V10.0.5] #3 drawTableFromObject called at [/var/www/projeqtor/view/objectDetail.php:361]
Same issue with Firefox or Chrome. Same issue with Problems and Opportunities
If you have any idea how to fix !
Many thanks.
Matthieu.
09 Sep 2022 11:08 #2 by babynus
Replied by babynus on topic Issue during Risk creation
This is an issue on V10.0.0, wich was not a stable release.If you can retreive logs for this install, you'll see creation for some tables, including risks, failed.You'll have to re-execute creation.Script attached
09 Sep 2022 11:14 #3 by matthieu.froment
A risk for the data still created in the database ?
09 Sep 2022 11:23 #4 by babynus
No.
(but it's a good practice to always backup your database before executing any script)
09 Sep 2022 12:49 #5 by matthieu.froment
Issue solved. Many thanks !
