ProjeQtOr free project management software - Cron is not starting - ProjeQtOr
31 Aug 2022 15:48 #1 by almarena-it
Hi there,
I hope you are doing well. I am new in the ProjeQtOr community, so apologize me in advance if I ask dumb questions.
I have just installed a new instance of ProjeQtOr V10.0.4 but I can't manage to get the cron working. Each time I try to start the cron, the cron activation button comes back in red.
You will find below what I get in the log file :
2022-08-31 11:42:53.185 ***** ERROR ***** [V10.0.4] EXCEPTION *****
2022-08-31 11:42:53.185 ***** ERROR ***** [V10.0.4] on file '/www/xxx/public/model/Cron.php' at line (434)
2022-08-31 11:42:53.185 ***** ERROR ***** [V10.0.4] cause = Call to undefined function getmypid()
2022-08-31 11:42:53.185 ***** ERROR ***** [V10.0.4] => #0 /www/xxx/public/tool/cronRun.php (33) -> run()
For information, the php user has write access on directory /www/xxx/public/files/cron
Could you tell what is going on and if I have done something wrong ? Thank you for your feedback.
Olivier
01 Sep 2022 18:42 #2 by babynus
Replied by babynus on topic Cron is not starting
It ssems your PHP configuration disabled the function getmypid
Check the parameter disable_functions in your php.ini
The following user(s) said Thank You: almarena-it
