ProjeQtOr free project management software - Use switched mode - ProjeQtOr
Use switched mode
25 Jan 2012 14:11 #1 by ekolossov
Use switched mode was created by ekolossov
In planning tab the switched mode should show the gantt chart not selected activity (or empty screen if there no delection)
25 Jan 2012 14:59 #2 by babynus
Replied by babynus on topic RE : Use switched mode
I cannot reproduce.
My test case :
- Open application
- Select switched mode
- Select planning : Gantt is displays
- Select activity : List is displayed
- Select one activity : switched to detail of activity
Could you describe the use case where the issue appears.
25 Jan 2012 15:08 #3 by ekolossov
Replied by ekolossov on topic RE : Use switched mode
If you first go to the planning and after that select switched mode you will reproduce it
Evgueni
25 Jan 2012 16:21 #4 by babynus
OK.
I changed default behaviour :
Existing :
When selecting switched mode, detail of element is displayed, because in most cases switched mode is used to expend detail (have full view of element) => when no item is selected this leads to no item displayed in full screen :(
New :
When selecting switched mode, if item is selected, detail is displayed (list is hidden), if no item is selected, list (or Gantt) is displayed
This will be deployed in V2.0
25 Jan 2012 16:37 #5 by ekolossov
Thanks - this will do the job
Evgueni
