ProjeQtOr free project management software - [SOLVED] Screen Customization plugin - Page 2 - ProjeQtOr
22 Aug 2022 16:46 #7 by babynus
Replied by babynus on topic Screen Customization plugin
Can you try and install attached patch ? (install it like a plugin)
It includes some fix ready for V10.0.5 that may solve your issue (it would explain
22 Aug 2022 16:58 #8 by pdecloedt
It doesn't work.
I just install the patch, go to customize Menu, select Project on the top combo box...
22 Aug 2022 16:59 #9 by pdecloedt
2022-08-22 16:54:52.857 ===== TRACE ===== New plugin found : pluginPatchV10.0.zip
2022-08-22 16:54:52.857 ===== TRACE ===== Plugin unzipped succefully
2022-08-22 16:54:52.859 ===== TRACE ===== Plugin descriptor information :
2022-08-22 16:54:52.859 ===== TRACE ===== => name : pluginPatchV10.0
2022-08-22 16:54:52.859 ===== TRACE ===== => description : corrective patch on version V10.0
2022-08-22 16:54:52.859 ===== TRACE ===== => version : 20220822.141223
2022-08-22 16:54:52.859 ===== TRACE ===== => compatibility : V10.0.0
2022-08-22 16:54:52.864 ===== TRACE ===== Plugin pluginPatchV10.0 V20220822.141223 completely deployed
2022-08-22 16:55:12.034 ===== TRACE ===== Calcul automatique du planning : calcul différentiel - début - Projets : 2,5,8,33,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,63,65,70,75,77,85,90,105,119,121,126,129,133,138,139,140,194,199,240,258,259,267,269,292,301,302,323,331,334,339,344,346,348,351,357,358,362,364,365,366,367,368,374,376,379,380,384,385,386,387,388,390,391,393,396,397,399,400,401,402,403,404,405,406,407,408,409,418,422,426,429,441,447,448,449,470,478,481,500,503,506,507,513,515,518,530,541,543,544,548,551,569,577,578,590,591
2022-08-22 16:55:12.366 ***** ERROR ***** [V10.0.4] Customization issue for Project | _tab_2_2
2022-08-22 16:55:12.367 ===== TRACE ===== === SCREEN CUSTOMIZATION ISSUE =====================================
2022-08-22 16:55:12.367 ===== TRACE ===== Certaines customisations d'écran ne sont pas cohérentes :
2022-08-22 16:55:12.367 ===== TRACE ===== - Projet
2022-08-22 16:55:12.369 ***** ERROR ***** [V10.0.4] ERROR *****
2022-08-22 16:55:12.369 ***** ERROR ***** [V10.0.4] on file '/var/www/html/projeqtor/plugin/screenCustomization/screenCustomizationSaveField.php' at line (635)
2022-08-22 16:55:12.369 ***** ERROR ***** [V10.0.4] cause = Invalid argument supplied for foreach()
2022-08-22 16:55:18.734 ===== TRACE ===== Calcul automatique du planning : calcul différentiel - fin - résultat = Aucun projet à recalculer
22 Aug 2022 17:38 #10 by babynus
OK, there is an issue in the plugin.
We'll soon fix in (on V6.3 of the plugin).
You'll find attached fixed filed, to redeposit on projeqtor/model/custom , so you'll have the plugin work without waiting for the fix of the plugin
(be sure to deposit on custom directory ;) )
