ProjeQtOr free project management software - Import issue since migration in 10.0.0 and 10.0.1 working before - Page 2 - ProjeQtOr
21 Jul 2022 17:30 #7 by babynus
You can Use phpMyAdmin (select the table to fix and at bottom, use option to reapir
or use SQL query
REPAIR TABLE `expense`;
21 Jul 2022 17:33 #8 by loicr
I already try but i've got the answer :
"Ce type de table ne supporte pas les repair"
21 Jul 2022 17:42 #9 by babynus
Try OPTIMIZE
21 Jul 2022 18:26 #10 by loicr
"Table does not support optimize, doing recreate + ..."
Status :OK
OPTIMIZE seems to work but already have my trouble with import in expense table and cron bug.
26 Jul 2022 09:25 #11 by loicr
Babynus,
I finaly make all import but explanation that we could export table and create a similar one to import is not so simple :
For exemple on table "expense" when i make CSV on project expense, projeqtor generate a file called "expense ...." but for import in CRON i should name it "projectexpense..." instead of personal expense wich is in the same table with file called expense ...
Where could i find all named of file for import ? or could it be possible to change extract of csv in projeqtor to have correspondance with import name ?
Thanks for your support.
LR
