ProjeQtOr free project management software - [SOLVED] filter not shows result as expected! - ProjeQtOr
24 Jun 2022 12:31 #1 by chandrashekhar
Hi Expert,
I need help to resolve the issue I am facing using filter. For your reference please attached two jpgs: "Screenshot_1-filter" is showing filter I have applied & "Screenshot_1-filter-result" is showing result of filter applied. I can't understand how it's showing value 100% though I need result for not having 100 only!
24 Jun 2022 14:21 #2 by alainforma
hi
use that one : <= and 99 % it works well
24 Jun 2022 15:34 #3 by chandrashekhar
Thanks for reply.
I have not got solution yet! Please refer attachments.
27 Jun 2022 12:09 #4 by babynus
Check progress on the activity.
The filter applies on the activity but what is displayed is the progress for the resource on the activity.
