ProjeQtOr free project management software - Issue consistency checks - ProjeQtOr
20 Jun 2022 10:58 - 20 Jun 2022 10:58 #1 by pdecloedt
error when I fix issue...
see on log file:
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] Exception-[22003] SQLSTATE[22003]: Numeric value out of range: 1264 Out of range value for column 'validatedWork' at row 1
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] For query : update budgetelement set validatedWork='-37.8' , assignedWork='-16.7' , leftWork='-17.925' , plannedWork='21.735' , assignedCost='-4895.84' , leftCost='-5991.1' , plannedCost='7690.43' , totalAssignedCost='-4895.84' , totalPlannedCost='7690.43' , totalLeftCost='-5991.1' where id=16
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] Strack trace :
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] #0 Sql->query called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:1825]
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] #1 SqlElement->updateSqlElement called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:1280]
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] #2 SqlElement->saveSqlElement called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:831]
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] #3 SqlElement->save called at [/var/www/html/projeqtor/model/BudgetElement.php:208]
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] #4 BudgetElement->save called at [/var/www/html/projeqtor/model/OrganizationMain.php:813]
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] #5 OrganizationMain->updateSynthesis called at [/var/www/html/projeqtor/model/ProjectPlanningElementMain.php:275]
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] #6 ProjectPlanningElementMain->save called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:2003]
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] #7 SqlElement->saveDependantObjects called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:1938]
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] #8 SqlElement->updateSqlElement called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:1280]
2022-06-20 10:52:00.180 ***** ERROR ***** [V9.5.5] #9 SqlElement->saveSqlElement called at [/var/www/html/projeqtor/model/persistence/SqlElement.php:1085]
2022-06-20 10:52:00.181 ***** ERROR ***** [V9.5.5] #10 SqlElement->saveForced called at [/var/www/html/projeqtor/model/PlanningElement.php:1188]
2022-06-20 10:52:00.181 ***** ERROR ***** [V9.5.5] #11 PlanningElement->wbsSave called at [/var/www/html/projeqtor/model/PlanningElement.php:1200]
2022-06-20 10:52:00.181 ***** ERROR ***** [V9.5.5] #12 PlanningElement->wbsSave called at [/var/www/html/projeqtor/model/PlanningElement.php:1854]
2022-06-20 10:52:00.181 ***** ERROR ***** [V9.5.5] #13 PlanningElement->moveTo called at [/var/www/html/projeqtor/model/PlanningElement.php:1817]
2022-06-20 10:52:00.181 ***** ERROR ***** [V9.5.5] #14 PlanningElement->moveTo called at [/var/www/html/projeqtor/model/Consistency.php:220]
2022-06-20 10:52:00.181 ***** ERROR ***** [V9.5.5] #15 Consistency->fixOrder called at [/var/www/html/projeqtor/model/Consistency.php:139]
2022-06-20 10:52:00.181 ***** ERROR ***** [V9.5.5] #16 Consistency->checkWbs called at [/var/www/html/projeqtor/tool/adminFunctionalities.php:97]
2022-06-20 10:52:00.181 ***** ERROR ***** [V9.5.5] #17 include called at [/var/www/html/projeqtor/view/print.php:288]
Last edit: 20 Jun 2022 10:58 by pdecloedt.
22 Jun 2022 10:29 #2 by babynus
Replied by babynus on topic Issue consistency checks
Very strange, you have negative values in your budgets ...
Consistency tries to fix BBS number of the budget, and this recalculated consolidated values from expenses, that seem to have a negative sum...
We'll have a look if we can fix Consistency, but sure you budget will have issue (they won't store negative values)
