ProjeQtOr free project management software - [SOLVED] Issue with upgrade - ProjeQtOr
25 May 2022 07:10 #1 by _toriy
Issue with upgrade was created by _toriy
Hello!
I have an issue with upgrade from version 9.5.3 to 9.5.4
This is logfile:
2022-05-25 11:45:12.653 ***** ERROR ***** [V9.5.3] ERROR *****
2022-05-25 11:45:12.653 ***** ERROR ***** [V9.5.3] on file '/var/www/html/projeqtor/db/maintenance.php' at line (83)
2022-05-25 11:45:12.653 ***** ERROR ***** [V9.5.3] cause = fopen(../files/cron/MIGRATION): failed to open stream: Permission denied
Before that i recursive gave "777 permission to all projeqtor folder, but the error is still there.
I need some advice to fix this issue.
25 May 2022 08:44 #2 by babynus
Replied by babynus on topic Issue with upgrade
Look into folder files/cron
if file MIGRATION exists, delete it.
25 May 2022 08:57 #3 by _toriy
Replied by _toriy on topic Issue with upgrade
In files/cron folder only 3 files:
25 May 2022 09:05 #4 by babynus
Sure PHP cannot write the file MIGRATION in this folder
As you gave large wreite rights, you should have other security software that blocks access.
Maybe Selinux or something like that block the writing.
25 May 2022 09:39 #5 by _toriy
Yes, there was a problem with SELinux. Many thanks!
