ProjeQtOr free project management software - Issues with showing proper Symbols in project -> progress - ProjeQtOr
20 May 2022 02:10 #1 by Chri.s
Hi! :-)
hope you are doing fine. When checking project -> progress i got symbols like â‚¬ where there should (as i mention) be € or h (hours). Do i need to change anything in system (what/where - didn't find anything) or is this a bug?
Thanks in advance
20 May 2022 10:25 #2 by Arkhanje
It's probably an encoding problem. You must have imported data in the wrong encoding format. Re-import the same data but in the correct format this time. The encoding must be in UTF8_general_ci
