ProjeQtOr free project management software - copy function (project) - ProjeQtOr
23 Jan 2012 12:27 - 23 Jan 2012 12:30 #1 by JCDe
copy function (project) was created by JCDe
Problem with the copy function of project
I create a project template XXXX
XXXX: Project template => Project
Phase 1: Design => type: Phase
Task 1: ..... => Type: Task
Task 2: ..... => Type: Task
Phase 2: Validation => type: Phase
Task 3: ..... => Type: Task
Task 4: ..... => Type: Task
Milestone 1: CDC => Incoming milestone
Milestone 2: Delivery => Deliverable milestone
As I use the copy function: I check 'milestone & activity' but I get just
- project
- Phase Design
No task or milestone?
Another question:
You can copy a project to project?
YYYY: Project father template => Proje
XXXX: Project Children template => Project
Milestone 1: CDC
thank you
25 Jan 2012 17:03 #2 by babynus
Issue is registered as Ticket #539, for analysis.
About copy of project to project : no, project copy does not copy subproject.
If could be an improveent if there is a real need.
Now, you can easily copy a main template project, copy a template subproject, and move copied subproject to the copied main project.
