ProjeQtOr free project management software - [SOLVED] Creating Tickets by email doesn't work - ProjeQtOr
27 Apr 2022 07:59 - 12 Mar 2024 08:51 #1 by RoBra81
I'm using V9.5.3 and sent an email with subject "Warum geht das nicht" to create a ticket within ProjeQtOr. Unfortunately the ticket was not created (which worked in the past). The ProjeQtOr logfile says (containing parts of my subject after "concerning"):
2022-04-27 07:52:40.756 ----- DEBUG ----- User corresponding to email address is #5
2022-04-27 07:52:40.756 ===== TRACE ===== Could not retreive response (empty response) from 'xxx@xxx.com' mail concerning arum #eht
Could you please have a look on that?
Thanks in advance
Ronny
Last edit: 12 Mar 2024 08:51 by RoBra81.
27 Apr 2022 10:10 #2 by Arkhanje
We have made changes to password encryption.
Try entering the password for this box again, this should fix the problem
27 Apr 2022 10:15 #3 by RoBra81
Unfortunately that didn't work - same problem...
28 Apr 2022 09:17 #4 by babynus
Message is clear : system could not identify answer.
Just replying without adding text will insert no note.
Also note that message is expected "before" original message.
28 Apr 2022 09:39 #5 by RoBra81
I don't want to reply to an existing ticket. I have a ticket system for creating new tickets by mail - that worked long time but now (I think since upgrading to 9.5) it's not working any more...
28 Apr 2022 10:00 #6 by babynus
ProjeQtOr can now integrate answers to mails send by the system in mailbox defined to enter new tickets.
Maybe your email is formatted in a way that is understood by the system as answer to existing mail.
Could you please post an exemple of email sent ?
