ProjeQtOr free project management software - Client Contract - Tokens management - Modification - ProjeQtOr
26 Apr 2022 17:44 #1 by AMAZ
In Client Contract screen, I try to modify the number of ordered tokens.
I have a given number of tokens (in the screenshot 7350 tokens) and when I click on the pencil to modify it,
the pop-up indicates "51450 tokens" without any modification. If I click on OK, the table is updated with this 51450 tokens.
(At the beginning I had 105 tokens and the first time, it became 1050... When retry, it became 7350 and now 51450.
I don't find where this quantity number come from.
27 Apr 2022 10:27 #2 by Flou
Indeed it's weird, have you any error on your logs files ?
Do you have duplicates in your DB?
29 Apr 2022 09:32 #3 by AMAZ
Thanks for your answer.
I think we've found the problem :
We work with hours and not with days, so 1 day = 7 hours.
Each time I update the contract, it is automatically multiplied by 7.
Best regards,
Anaïs
29 Apr 2022 11:51 - 29 Apr 2022 11:52 #4 by Flou
Indeed you have find the problem !
For fixe this, change on tool/dynamicDialogWorkTokenClientContract.php ligne 91 :
value="<?php echo (isset($workTokenClientContract))? Work::displayWork($workTokenClientContract->quantity):'';?>"
by :
value="<?php echo (isset($workTokenClientContract))? $workTokenClientContract->quantity:'';?>"
Ticket #6168  has been recorded on the road map.
This fix while be available on V9.5.4.
Last edit: 29 Apr 2022 11:52 by Flou.
The following user(s) said Thank You: AMAZ
29 Apr 2022 15:55 #5 by AMAZ
There is the same issue on "Work units catalog", where hours are divided by 7 when click to modify a line.
Best Regards,
Anaïs
02 May 2022 15:41 #6 by Flou
Indeed you're right, we'll fix it.
Ticket #6170 has been recorded on the road map, the fix will be available on V9.5.4.
