ProjeQtOr free project management software - Screen Customisation - invisible parts - ProjeQtOr
22 Mar 2022 15:41 #1 by AMAZ
I wanted to add two fields for personnalized activity type "Training", in a dedicated section in "Activities" screen.
Section Formation
field 1
field 2
With screen customisation plug-in, I have first added the fields (section + 2 fields) after another section "to do list" ("Points à traiter" in French).
But the part (a table) that is after "to do list" section is invisible through this plugin. And when I moved my "Training" section,
then the to do list table came with it. (see attached screenshot)
Now I don't know how to put the table back in the to do list section. Could you please help me ?
Thanks for your help
25 Mar 2022 19:03 #2 by babynus
I  think you should be able to move you new section before section "Todo" (liste des points à traiter), just move it after "Acitivies" in section Sub-Activities.
The following user(s) said Thank You: AMAZ
