ProjeQtOr free project management software - [9.5.0] Undefined variable: col - ProjeQtOr
21 Mar 2022 14:08 - 21 Mar 2022 14:08 #1 by scud167
Hi, i got an error on ticket since the patch 9.5.0
2022-03-21 13:58:59.271 ***** ERROR ***** [V9.5.0] ERROR *****
2022-03-21 13:58:59.271 ***** ERROR ***** [V9.5.0] on file '/var/www/html/projeqtor/view/objectDetail.php' at line (4024)
2022-03-21 13:58:59.271 ***** ERROR ***** [V9.5.0] cause = Undefined variable: col
2022-03-21 13:59:12.817 ***** ERROR ***** [V9.5.0] ERROR *****
2022-03-21 13:59:12.818 ***** ERROR ***** [V9.5.0] on file '/var/www/html/projeqtor/view/objectDetail.php' at line (4024)
2022-03-21 13:59:12.818 ***** ERROR ***** [V9.5.0] cause = Undefined variable: col
Any idea ?
Thank you,
Gael
Last edit: 21 Mar 2022 14:08 by scud167.
21 Mar 2022 15:11 - 21 Mar 2022 15:23 #2 by Flou
I can't reproduce this issue, by i checked the code and it is possible to fix it by changing  ligne 4024  "$col" by "$colName" on objectDetail.php " in the else if condition.
Can you explain your case as I am trying to reproduce this and fix it completely for V9.5.1?
Last edit: 21 Mar 2022 15:23 by Flou.
21 Mar 2022 15:17 #3 by Flou
I was created a ticket #6046 on the roadmap.
I created a #6046 ticket on the roadmap. The final solution will be written to correct this in the result field of the ticket.
21 Mar 2022 15:40 #4 by scud167
Thank you for your quick response ^^ I can solve this problem by simply hiding the history in the user settings.
I tried to add the condition but the problem remains the same.
This problem only occurs when there are tickets created by the mail collector.
21 Mar 2022 15:58 #5 by Flou
Thank's i try to reproduce this and and i give you a solution to correct this when i was find the correction.
21 Mar 2022 16:41 - 21 Mar 2022 16:41 #6 by Flou
it's good, to correct this issue you must finally change the "SqlElement::isWork($colName)" by "and isset($colName) and SqlElement::isWork($colName)" on objectDetail ligne 4024.
Last edit: 21 Mar 2022 16:41 by Flou.
The following user(s) said Thank You: scud167
