ProjeQtOr free project management software - Screen customization: consistency issue - ProjeQtOr
10 Mar 2022 17:42 - 10 Mar 2022 17:44 #1 by bgenolini
I have a minor issue with the screen customization plugin v 6.0, ProjeQtOr v 9.4.
on the "organization" field, I get the following message:
Some screen customizations are not consistent any more with current version :
- Organization
Please access each screen on customization plugin to fix the issue (Plugin V5.0 or over is required)
However, it does not prevent from customizing the screen.
By accessing other screens as requested, I found others with the same message. Some errors were logged during the process (
File Attachment:
File Name: projeqtor_...0310.log
File Size:6 KB
Thanks in advance,
Bernard
Last edit: 10 Mar 2022 17:44 by bgenolini. Reason: Not sure that the attached file was correctly visible.
10 Mar 2022 17:53 #2 by babynus
The message is not a blocking issue.
Most of the time is has no side effect.
Could you please post here file projeqtor/model/custom/Organization.php
We'll have a look at errors in log file, but they are not related.
15 Mar 2022 10:01 #3 by bgenolini
Hello,Here it is.
Bernard
15 Mar 2022 11:03 #4 by babynus
Here is file fixed
15 Mar 2022 18:58 #5 by bgenolini
Thanks, but we still have the issue. But we are in v. 9.4.2. Do you think this is fixed in 9.4.3?
Bernard
15 Mar 2022 19:14 - 15 Mar 2022 19:14 #6 by babynus
Issue ((in fact just warning message) is due to customization, so won't be fixed in community version.
You have to copy fixed file in model/custom (unzipped)
Last edit: 15 Mar 2022 19:14 by babynus.
