ProjeQtOr free project management software - Screen customization plugin issue - Page 2 - ProjeQtOr
02 Feb 2022 15:37 #7 by babynus
In fact issue is weird.
We are on a ActivityPlanningElement (class where issue occurs) and it seems the refType/refId refers to a Project...
This is unconsistant.
We put a workaround in V9.4.3 to avoid this error, but their seems to be some unconsistency in your DB.
Maybe a Consistency check (in Adlin screen) may help.
02 Feb 2022 18:42 #8 by bgenolini
The check reported some issues. Fixing them did not solve the problem.
I guess that because those issues were related to manipulations we did long before the update, and that had no effect when we used this screen customization.
There is another issue: in the Project section, I observe a "hidden" picture at the progress and treatment parts, whereas they are not hidden (checked with the edit window).
We also observed a change in the name of a custom variable when upgrading from v. 9.3.5 to v. 9.4.2. I tried to reset the screen disposition: it does not work.
Bernard
03 Feb 2022 08:56 #9 by babynus
Please show screenshot of the issues you face.
03 Feb 2022 10:32 #10 by bgenolini
Here it is. I highlighted the section and the edit popup showing the discrepancy.
Bernard
12 Feb 2022 12:11 #11 by babynus
Are you editing screen Project or Activity ?
Please post here files projeqtor/model/custom/Project.php and projeqtor/model/custom/Activity.php
