ProjeQtOr free project management software - (Solved) [9.4.2] Project selector - ProjeQtOr
20 Jan 2022 13:16 #1 by Juanbeizh
since 9.4.2 upgrade, I've noticed that in project selector, I can see all projects, including those which I don't have access (no R/W rights).
I've checked User parameters / Automation / Projects / restrict project list : Yes, but seems not useful in this case.
How can I restrict this view to my projects only ?
Erwann
20 Jan 2022 14:08 #2 by babynus
Replied by babynus on topic [9.4.2] Project selector
While fixing an incorrect value for access right we changed to a too permissive value for some screens.
We'll fix it in next patch.
In the mean time, you can easily fix it in the Habilitation screens.
Go to "Access to data (project dependant)"
Look for values that are Manager+ and change to Manager for profiles that should not have a global view.
You should have to change values for screens "Call for Tender", "Tender", "Individual Expenses", "Project Expense", "Client Quotation", "Client Command"
The following user(s) said Thank You: Juanbeizh
20 Jan 2022 14:31 - 20 Jan 2022 14:38 #3 by Juanbeizh
Replied by Juanbeizh on topic [9.4.2] Project selector
Hi Babynus,
thanks for your help !
Note : after changing Manager+ to Manager for Outgoing and Incoming Mail : everything seems OK
Thanks !
Erwann
Last edit: 20 Jan 2022 14:38 by Juanbeizh.
20 Jan 2022 14:39 #4 by Juanbeizh
Juanbeizh post=32146 wrote: Hi Babynus,
Thanks !
Erwann
