ProjeQtOr free project management software - Issue at project creation | table planningelement missing - ProjeQtOr
10 Jan 2022 15:21 - 10 Jan 2022 15:39 #1 by Edlonar
Hi
I have an issue when I want to create a new project (I have this problem with version 9.3.5 and 9.4.1). It seems that the planningelement table is missing.
Please find bellow the log:
2022-01-10 15:14:51.138 ***** ERROR ***** [V9.4.1] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 La table 'projeqtor.planningelement' n'existe pas
2022-01-10 15:14:51.163 ***** ERROR ***** [V9.4.1] For query : select * from planningelement where idProject in (0) and idProject not in (0) and refType= 'Project' and idle=0 order by wbsSortable asc
2022-01-10 15:14:51.164 ***** ERROR ***** [V9.4.1] Strack trace :
2022-01-10 15:14:51.171 ***** ERROR ***** [V9.4.1] #0 Sql->query called at [C:\wampserver\www\Joomla\projeqtor\model\persistence\SqlElement.php:2834]
2022-01-10 15:14:51.172 ***** ERROR ***** [V9.4.1] #1 SqlElement->getSqlElementsFromCriteria called at [C:\wampserver\www\Joomla\projeqtor\view\main.php:2259]
2022-01-10 15:14:53.624 ***** ERROR ***** [V9.4.1] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 La table 'projeqtor.delivery' n'existe pas
2022-01-10 15:14:53.626 ***** ERROR ***** [V9.4.1] For query : select idproject, done, idle, count(*) as cpt from delivery where idProject in (0) group by idproject, done, idle
2022-01-10 15:14:53.627 ***** ERROR ***** [V9.4.1] Strack trace :
2022-01-10 15:14:53.629 ***** ERROR ***** [V9.4.1] #0 Sql->query called at [C:\wampserver\www\Joomla\projeqtor\model\persistence\SqlElement.php:3077]
2022-01-10 15:14:53.630 ***** ERROR ***** [V9.4.1] #1 SqlElement->countGroupedSqlElementsFromCriteria called at [C:\wampserver\www\Joomla\projeqtor\view\today.php:68]
2022-01-10 15:14:53.696 ***** ERROR ***** [V9.4.1] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 La table 'projeqtor.planningelement' n'existe pas
2022-01-10 15:14:53.698 ***** ERROR ***** [V9.4.1] For query : select * from planningelement where refType='Project' and refId in (0) and idle=0 order by wbsSortable
2022-01-10 15:14:53.699 ***** ERROR ***** [V9.4.1] Strack trace :
2022-01-10 15:14:53.701 ***** ERROR ***** [V9.4.1] #0 Sql->query called at [C:\wampserver\www\Joomla\projeqtor\model\persistence\SqlElement.php:2834]
2022-01-10 15:14:53.702 ***** ERROR ***** [V9.4.1] #1 SqlElement->getSqlElementsFromCriteria called at [C:\wampserver\www\Joomla\projeqtor\model\UserMain.php:884]
2022-01-10 15:14:53.703 ***** ERROR ***** [V9.4.1] #2 UserMain->getHierarchicalViewOfVisibleProjects called at [C:\wampserver\www\Joomla\projeqtor\view\today.php:184]
2022-01-10 15:14:53.704 ***** ERROR ***** [V9.4.1] #3 showProjects called at [C:\wampserver\www\Joomla\projeqtor\view\today.php:1143]
2022-01-10 15:15:22.925 ***** ERROR ***** [V9.4.1] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 La table 'projeqtor.planningelement' n'existe pas
2022-01-10 15:15:22.927 ***** ERROR ***** [V9.4.1] For query : select project.id as id, projectplanningelement.wbsSortable as wbsSortable, project.name as name, T1.name as nameProjectType, project.color as color, convert(concat(COALESCE(T2.sortOrder,''),'#split#',T2.name,'#split#',COALESCE(T2.color,'')) using utf8) as colorNameStatus, projectplanningelement.progress as progress, projectplanningelement.plannedEndDate as plannedEndDate,project.idProject as idproject from project left join planningelement as projectplanningelement on (projectplanningelement.refId=project.id and projectplanningelement.refType='Project') left join type as T1 on project.idProjectType = T1.id left join status as T2 on project.idStatus = T2.id where project.idle=0 and ( ((project.id not in (0) or project.id is null ) and (project.id not in (0) or project.id is null or (project.idResource=1) ) and (project.id not in (0) or project.id is null or (project.idUser='1') )) or project.codeType='TMP' ) order by projectplanningelement.wbsSortable , project.sortOrder
2022-01-10 15:15:22.928 ***** ERROR ***** [V9.4.1] Strack trace :
2022-01-10 15:15:22.929 ***** ERROR ***** [V9.4.1] #0 Sql->query called at [C:\wampserver\www\Joomla\projeqtor\tool\jsonQuery.php:753]
2022-01-10 15:15:26.821 ***** ERROR ***** [V9.4.1] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 La table 'projeqtor.planningelement' n'existe pas
2022-01-10 15:15:26.823 ***** ERROR ***** [V9.4.1] For query : desc planningelement
2022-01-10 15:15:26.824 ***** ERROR ***** [V9.4.1] Strack trace :
2022-01-10 15:15:26.825 ***** ERROR ***** [V9.4.1] #0 Sql->query called at [C:\wampserver\www\Joomla\projeqtor\model\persistence\SqlElement.php:3975]
2022-01-10 15:15:26.827 ***** ERROR ***** [V9.4.1] #1 SqlElement->getFormatList called at [C:\wampserver\www\Joomla\projeqtor\model\persistence\SqlElement.php:3517]
2022-01-10 15:15:26.828 ***** ERROR ***** [V9.4.1] #2 SqlElement->getDataType called at [C:\wampserver\www\Joomla\projeqtor\model\persistence\SqlElement.php:3522]
2022-01-10 15:15:26.829 ***** ERROR ***** [V9.4.1] #3 SqlElement->getDataType called at [C:\wampserver\www\Joomla\projeqtor\view\objectDetail.php:1532]
2022-01-10 15:15:26.830 ***** ERROR ***** [V9.4.1] #4 drawTableFromObject called at [C:\wampserver\www\Joomla\projeqtor\view\objectDetail.php:354]
2022-01-10 15:15:31.689 ***** ERROR ***** [V9.4.1] ERROR *****
2022-01-10 15:15:31.691 ***** ERROR ***** [V9.4.1] on file 'C:\wampserver\www\Joomla\projeqtor\model\ProjectPlanningElementMain.php' at line (286)
2022-01-10 15:15:31.692 ***** ERROR ***** [V9.4.1] cause = A non-numeric value encountered
Many thanks for your help.
Last edit: 10 Jan 2022 15:39 by Edlonar. Reason: English translation
10 Jan 2022 15:30 #2 by babynus
PLEASE RESPECT FORUM RULES
10 Jan 2022 15:42 #3 by Edlonar
English translation done.
Sorry.
best regards
10 Jan 2022 15:57 #4 by babynus
Check your DB.
Does table "planningelement" exist ?
10 Jan 2022 16:05 #5 by Edlonar
Planningelement is in the table list but when I click on it (phpMydamin), I have this erreor : "#1146 - 'projeqtor.planningelement' doesn't exist."
(Apache 2.4.33 | PHP 7.2.4 | MySQL 5.7.21).
10 Jan 2022 16:22 #6 by babynus
So you have an issue on your DB.
Possibly access rights on some tables does not allow DB user to access this table.
