ProjeQtOr free project management software - [Solved] Creator and changer of milestones is not able to set target date - ProjeQtOr
07 Dec 2021 06:21 - 09 Dec 2021 09:41 #1 by RoBra81
I gave the project team the right to create and change milestones but they are note able to set the target date (input field not editable) - did I forget to set one specific right for them?
Ronny
Last edit: 09 Dec 2021 09:41 by RoBra81.
09 Dec 2021 09:30 #2 by babynus
You can change the "validated" target date, but not the "Planned" target date (wich is calculated)
So you must give these users capacity to change the validated data (it is a specific access right)
The following user(s) said Thank You: RoBra81
09 Dec 2021 09:41 #3 by RoBra81
That works! Thank you very much!!
