ProjeQtOr free project management software - KPI Deliverable for project Report issue - ProjeQtOr
03 Dec 2021 14:19 #1 by karl.binet
Projeqtor Version V9.3.4
It's appears that the bottom summary in the report is not accurate, it is not showing the correct value.
Can you have a look at this issue, or maybe i'm just missing something,
Karl
03 Dec 2021 17:54 #2 by babynus
We'll have a look.
03 Jan 2022 15:50 #3 by babynus
Global value (%) is weighted average.
The weight is the value of the "importance".
So if all values are zero, weighted average is zero.
20 Jan 2022 16:16 - 20 Jan 2022 16:19 #4 by karl.binet
Hi
thank you for your answer, here are my comments
We understand well how the calculation is made, our question is more about the results that are displayed seem inconsistent with what we find in the database
So referring to the data in report/kpiDeliverable.php, we understand that the values of the tables kpiHistory and kpiValue are used.
However, these values do not seem to be in harmony
kpivalue
According to our calculations, the value in the database is good è 73% advancement
Our Internal Dashboard that calculates the same thing by compiling the table of deliverables :
kpihistory
gives us no results
If we look at another project: 4828
Values are incomplete and incorrect  :
The value of our dashboard and the kpiValue table are good « 96% » :
kpiHistory
So it seems that the assembly of the summary table by weeks in the report does not show the right values, although they are compiled correctly in the database.
Last edit: 20 Jan 2022 16:19 by karl.binet.
25 Jan 2022 12:07 #5 by babynus
The difference you mote mayu come from the point that the report always takes the latest value of the Kpi for a period, and not the average of all walues.
10 Feb 2022 13:51 #6 by karl.binet
Thanks for your answer. Unfortunately, we are not averaging while doing our calculation. We have tested on a fresh install v 9.4.3. with 2 deliverables of same weight (high) : first one at 100% (completed/accepted without reservations) and the other one not done (0%).
Our understanding of the formulas is :
SUM( status(%) * weight) / SUM(weight)
So, with our example (high weight = 1 – by default) :
((100% *1) + (0% * 1)) / (1 +1) = 50% KPI
1 / 2 = 50% KPI
KPI does not seem to reflect our previous result (50%) in the table (0%) neither is the graph (near 65%)
Our question is the following:
Is our understanding of the formula and the report values wrong?
Time to create page: 0.084 seconds
