ProjeQtOr free project management software - Sreen customization compatibility issue - ProjeQtOr
25 Nov 2021 14:40 #1 by dcornillon
My organization moved from Projeqtor version 8.6.4 to 9.3.1, this is a huge step. New interface is a bit disturbing at first, but after some browsing it become more user friendly!
Anyway this is not the subject. We previously used the Sreen Customization plugin v5.1. Since upgrade to v9.3.1 your custom screens are not customized anymore. Investigations showed a compatibility issue.
When selecting this plugin a popup tells this functionality is not available in this version of Projeqtor.
Can someone tell me what to do?
Thank
25 Nov 2021 17:06 - 25 Nov 2021 17:06 #2 by babynus
Your migration process was wrong.
You built a new directory with new code, so did not include customizations.
Correct way to migrate is, as explained on website, to overwrite existing code with new one, so that you preserve customizations and access to installed plugins.
Last edit: 25 Nov 2021 17:06 by babynus.
25 Nov 2021 17:39 #3 by dcornillon
Thank for your feedback. Do you speak about this documentation  www.projeqtor.org/files/readme.txt ?
Unfortunately I have no access to the previous directory. I only got the installation back thank to a database backup.
Is there a way to customize my screens again,  based on my database? I mean can I deduce previously created or customized fields by analysing the database structure?
26 Nov 2021 14:42 #4 by babynus
No, I was dealing with website info : www.projeqtor.org/en/product-en/technica...413-product-setup-en
No easily. You must compare standard table with your own to find differences (and this most of the tables)
