ProjeQtOr free project management software - CTRL+S doesn't - ProjeQtOr
CTRL+S doesn't
21 Oct 2021 11:31 - 24 Dec 2021 08:22 #1 by fxpourtier
Thank you for ProjeqtOr. It change my life. It's a great solution :-)
I was in 9.2.1 and I update to version 9.3.1 but CTRL+S doesn't work on every screen when I want save :-(
For update, I stop apache, delete directory "ProjeQtOr" and unzip new version in the same directory and start apache.
It's a issue of me , easyPHP WebServer or ProjeQtOr ?
Thank you for your answer :-)
Last edit: 24 Dec 2021 08:22 by fxpourtier.
21 Oct 2021 12:05 #2 by babynus
Replied by babynus on topic CTRL+S doesn't
Hi
No, you must not "delete" directory.
Just overwrite existing with content of zip.
21 Oct 2021 12:44 #3 by fxpourtier
Replied by fxpourtier on topic CTRL+S doesn't
Ho my god :-(
thank you for you quick answer :-)
20 Dec 2021 17:40 #4 by pajarojuarez
Replied by pajarojuarez on topic CTRL+S doesn't
Good morning, I have updated the Projeqtor version from 9.1.1 to version 9.3.5 and I have noticed that the shortcut "Ctrl-S" stopped responding.
I have previously made other updates (8.3 to 9.1.1) and never had this problem.
23 Dec 2021 15:15 #5 by babynus
CTRL+S still working fine for me.
Be sure to clean browser cache.
If problem persists, check for errors in browser console and post errors here.
23 Dec 2021 16:51 #6 by fxpourtier
Quick update : The issue is on the old graphical user interface. When i switch to New graphical user interface, CRTL-S work fine.
Since this issue, i use the new interface ;-)
Thanks for your help :-)
The following user(s) said Thank You: pajarojuarez
