ProjeQtOr free project management software - [SOLVED] Postgres - COLUMN_COMMENT Missing in INFORMATION_SCHEMA.COLUMNS - ProjeQtOr
20 Sep 2021 21:07 #1 by sensemila
I have many error in my log file, i have multpile entry with this message :2021-09-20 17:30:22.138 ***** ERROR ***** /color][color=#569cd6]V9.2.2[/color][color=#d4d4d4    For query : SELECT COLUMN_COMMENT as comment FROM INFORMATION_SCHEMA.COLUMNS  WHERE TABLE_SCHEMA='securite' AND TABLE_NAME='projeqtorproject' AND COLUMN_NAME='idprojeqtortask'
This query in sqlelement.php not working on postgres SQL$sqlColumn="SELECT COLUMN_COMMENT as comment FROM INFORMATION_SCHEMA.COLUMNS "           ." WHERE TABLE_SCHEMA='$dbName' AND TABLE_NAME='$tableName' AND COLUMN_NAME='$dbFieldName'";
How i can fix the issue ?
Thanks a lot
21 Sep 2021 12:19 - 21 Sep 2021 13:59 #2 by babynus
Replace line 4004 in model/persistence/SqlElement.php
from
      } else if ($type=='int' or $type=='int(10)' or $type=='int(11)') {
to
      } else if (($type=='int' or $type=='int(10)' or $type=='int(11)') and !Sql::isPgsql()) {
Last edit: 21 Sep 2021 13:59 by babynus.
The following user(s) said Thank You: sensemila
22 Sep 2021 11:15 - 22 Sep 2021 11:16 #3 by sensemila
is Perfect :)
Thank for your help
Last edit: 22 Sep 2021 11:16 by sensemila.
