ProjeQtOr free project management software - V9.2.3 - Adding document issue - ProjeQtOr
16 Sep 2021 09:56 - 16 Sep 2021 10:24 #1 by ashofphoenix
Just installing the 9.2.3 Version and create a new project, putting me as a ressource with "gestionnaire" right for R/W/M documents
Clicking the add document and been said "you don't have access right to access this element"
Checking with admin account = good .
Any clues ?
Last edit: 16 Sep 2021 10:24 by ashofphoenix. Reason: #bescherelle
17 Sep 2021 09:59 #2 by babynus
V9.1 introduces access rights on directories.
Check that your user has rights to store the documents on the selected directory
17 Sep 2021 14:03 - 17 Sep 2021 14:18 #3 by ashofphoenix
Using LDAP to authentifcate to projeqtor, I added my user LDAP group & myself personally on the security properties tab of the root document directory set onto Projeqtor configuration.
I gave full control access to directory+child directory and I check that security on all child directory is properly set on child dir
Still can't add documents.
Note : my admin account of projeqtor is not on LDAP and have no proper "windows right" onto that document directory but can add documents. So when you say "check that your user has right access".. at which level are you talking about ?
Last edit: 17 Sep 2021 14:18 by ashofphoenix. Reason: #precision
17 Sep 2021 14:51 #4 by ashofphoenix
ok. I checked something.
- my account is set as a ressource of the project with a "project leader" profile
- project leader is set with "gestionnaire" rights (Read/Create/update/suppress - on its projects) on all document directories.
- With this level of access, I can't create documents.
- I modified right access of project leader with "gestionnaire+" right.
- With this level of access, I CAN create documents.
So it means to be like either "gestionnaire" access "on its projects" has a problem OR that it's like my account is not considered "as a ressource" of my project ??
Any other clues ?
17 Sep 2021 20:17 - 17 Sep 2021 20:20 #5 by babynus
I cannot reproduce.
I have same test case on Demo.
Project Leader is "Manager" (Gestionnaire" in french).
He is also "Manager" on Document access rights
Connected as Manager (profile Project Leader), creation of document is fine
Pay attention that with this configuration you cannot add document to directory dedicated to a project you are not allocated as Project Leader.
You can try on Demo with user "manager"
Last edit: 17 Sep 2021 20:20 by babynus.
30 Sep 2021 09:06 #6 by ashofphoenix
here is mine...
Time to create page: 0.061 seconds
