ProjeQtOr free project management software - Create notification for Leave Period - Page 2 - ProjeQtOr
14 Sep 2021 18:36 #7 by mcanuto
I looked into my production table (v9.2.2)  and my test table (v9.2.3, upgraded today) and they are identical:
And I'm not sure I can see an issue. I found a way to create the notification, but I need to delete the "[]" of the notifiable element at the top, to fill all the form and retype them to save. But I don't think this is the normal way to use it.
Can you tell me what's wrong in my table, please?
MCanuto
15 Sep 2021 09:24 #8 by babynus
It seems you entered some values manually in the table (id 82 & 83)
they are different from what is inserted through migration
INSERT INTO `${prefix}notifiable` (`notifiableItem`,`name`,`idle`) VALUES
    ('Leave','Leave',0),
    ('EmployeeLeaveEarned','Leave Earned',0),
    ('Workflow','Workflow',0),
    ('Status', 'Status',0),
    ('LeaveType', 'Leave Type',0);
We don't support this kind of changes
08 Oct 2021 11:20 #9 by mcanuto
Hello, Babynus,
I'm pretty sur we never add records to that table manually.
It seems like the ID 82, 83 and 86 got a name in french instead of the english one on your query.
Anyway, is there a possibility to undo it and fix the content of this table?
If we delete those records and run your query again, would it have any other impact on any other table?
At least, can you tell me in which version it was added to the database?
Thank you for any help you can provide.
Best regards,
MCanuto
13 Oct 2021 15:37 - 13 Oct 2021 15:38 #10 by babynus
Yes update the table
No, only notifications are impacted with notifiable.
V8.0.0 (it was when I was young...)
Last edit: 13 Oct 2021 15:38 by babynus.
02 Feb 2022 10:53 #11 by mcanuto
Sorry, I took a long time to get back to you on this.
Once the table updated, it's working.
Just another question. On the notification, I cannot use the information of the Leave Type, which can be important. Is that something planned to be available on the future?
MCanuto
02 Feb 2022 14:19 #12 by babynus
As designed for this feature, all fields available are proposed.
So the Leave Type may not be directly avaialble.
