ProjeQtOr free project management software - [SOLVED] Global planning display issue - ProjeQtOr
02 Sep 2021 09:12 #1 by nhedhili
Hello ,
we were in version 9.0 we are actually in version 9.2.2 , in the global planning view we see only the tasks  we do not see tickets or any other element , this behavioue is the same since the last versions that we had. We never did any migaration to database or any thing else we only do updating to projeqtor regulary when a new version is published.
thank you for your help and assistance.
02 Sep 2021 09:20 #2 by Arkhanje
What version of projeqtor are you using? Have you checked that you have the right to see these elements? (Screen rights, reading rights ....) and what do the logs say?
It may be silly but have you remembered to check the boxes in question so that the requested items are displayed. If they are, uncheck and re-check them.
02 Sep 2021 10:00 - 02 Sep 2021 10:04 #3 by nhedhili
    hello thank you for your answer ,
1- I m logged in as administrator and I checked other porfiles same behaviour
2- we see on ly tasks , milestones and test sessions/cases
3- WE are in version 9.2
4- I created one ticket and one livrable item , to test but only we see tasks , use cases and milestones in global planning even though I check and uncheck them
5-If I check all items nothing appears on the screen of global planning
6-version is the last version 9.2.2
please see screen pictures joined to this message
Last edit: 02 Sep 2021 10:04 by nhedhili.
03 Sep 2021 18:36 #4 by nhedhili
Any feedback please
07 Sep 2021 12:00 #5 by babynus
Do you have errors in the log file ?
07 Sep 2021 13:55 #6 by Coasterman
In our case changing the database to utf8 helped (default was utf8mb4, which didn't work).
We changed changed the database configuration instead of implementing the workaround mentioned in following ticket
www.projeqtor.org/en/forum/2-submit-issu...lobal-planning#30577
