ProjeQtOr free project management software - [9.1.5->9.2.2] Strange plugins behavior - ProjeQtOr
02 Aug 2021 17:21 #1 by fsouliers
- Plugin application update : the v9.2.2 was marked instable and 9.3.0 already visible (and also marked instable) ... and I couldn’t download V9.2.2 (but downloading v9.3.0 was Ok). Well, I manually downloaded 9.2.2 zip and triggered install from the gui and upgrade process seemed to work properly.
- Plugin screen customisation (5.3) : since upgrade, I have the following error message :2021-08-02 17:16:59.437 ===== TRACE ===== === SCREEN CUSTOMIZATION ISSUE =====================================
2021-08-02 17:16:59.437 ===== TRACE ===== Certaines customisations d'écran ne sont pas cohérentes :
2021-08-02 17:16:59.437 ===== TRACE ===== - Projet
2021-08-02 17:16:59.444 ===== TRACE ===== Les customisations ont été corrigées automatiquement
... but I can’t see what changed (and the error message is persistant).
Do you have any idea ?
09 Aug 2021 13:01 #2 by babynus
This is fixed.
=> 9.2.2 is stable
=> 9.3.0 not visible (it was deployment for test of version under development)
