ProjeQtOr free project management software - API write issue (PUT / POST) - ProjeQtOr
07 Jul 2021 12:23 #1 by caccia
We are trying to implement some actions using the REST API, in a Java application.
This works fine for GET actions, but fails for PUT or POST.
We seem to have a problem with the implementation of the AES-CTR encryption / decryption : the Java library expects an IV (Initialization Vector) parameter in the encryption function, but there doesn't seem to be such a parameter in the PHP-AES version.
Do you know how we should set this IV parameter ? (tried setting it to NULL without success)
Code used is attached below.
File Attachment:
File Name: Launch-java.txt
File Size:2 KB
Cheers
03 Dec 2021 18:29 - 03 Dec 2021 18:35 #2 by kobetsu
And this is the problem I think many persons reported on the forum. Projeqtor uses PHP library for AES:CTR create by Chris Veness (www.movable-type.co.uk/scripts/aes.html). This library uses it's own implementation of AES CTR and generate VI (key) base on password passed to function. Problem is this VI (key) is generated in a little complicated way.
I tried to connect C# to Projeqtor API and point was (probably like you and many others) how to encrypt data in C# using AES CTR. To do this you need to know VI key.
Take a look for projeqtor source code - you can find like like this:
$data=AesCtr::decrypt($dataEncoded, $user->apiKey, Parameter::getGlobalParameter('aesKeyLength'));
As you can see data you send to projeqtor via api are decrypted using function AesCtr:decrypt (from library I mentioned above) and as secret user_api_key is used. There is nowere passed VI key which we are looking for. Again this VI key is generated from user_api_key.
What is inside AesCtr:decrypt:
public static function encrypt($plaintext, $password, $nBits)
$blockSize = 16; // block size fixed at 16 bytes / 128 bits (Nb=4) for AES
if (!($nBits == 128 || $nBits == 192 || $nBits == 256)) return ''; // standard allows 128/192/256 bit keys
// note PHP (5) gives us plaintext and password in UTF8 encoding!
// use AES itself to encrypt password to get cipher key (using plain password as source for
// key expansion) - gives us well encrypted key
$nBytes = $nBits / 8; // no bytes in key
$pwBytes = array();
for ($i = 0; $i < $nBytes; $i++) $pwBytes[$i] = ord(substr($password, $i, 1)) & 0xff;
$key = Aes::cipher($pwBytes, Aes::keyExpansion($pwBytes));
$key = array_merge($key, array_slice($key, 0, $nBytes - 16)); // expand key to 16/24/32 bytes long
So as you see generally user_api_key (used as secret) is expanded and itself again ecrypted by AES. A little complicated to implemenet outside projeqtor.
Unless my analysis is wrong, projeqtor should use something standard (standard for whole world not PHP only).
Last edit: 03 Dec 2021 18:35 by kobetsu.
10 Feb 2022 16:05 #3 by MagicBuzz
Hello kobetsu,
I'm trying to write an interface with C# and face the same problem.
Did you finally found a workarround or do you have a C# code sample that works?
I'm stuck there, and I would avoid to wrap and PHP call from my C# program...
10 Feb 2022 17:25 #4 by kobetsu
We extended API of PQ by method allowing us to encrypt passed text. It was the easiest way for us.
10 Feb 2022 18:21 - 10 Feb 2022 18:23 #5 by MagicBuzz
Thank you for your answer.
I wonder if I will get in the same direction.
I would have prefered to stay unchanged PQ code, but the way the Encrypt function works is making me mad!
I'm running this PHP code from my C# program :
error_reporting(E_ERROR | E_PARSE); // AesCtr::encrypt produces warnings
require_once "aes.class.php"; // From ProjeQtOr source
require_once "aesctr.class.php"; // From ProjeQtOr source
$filename = 'json.dat'; // Input message "{"id":"11", "figgoId":"30"}"
$contents = file_get_contents($filename);
$data = AesCtr::encrypt($contents, $_SERVER['argv'][1], 256);
file_put_contents($filename, $data);
It update my file from
{"id":"1","figgoId":"5"}
To some crypted phrase :
cQJXBgVIBWLhCDG90KlyKw7zZ5093Yjunso75kwBSUPATK8=
Then I send it to the API :
var formContent = new FormUrlEncodedContent(new
new KeyValuePair<string, string>;("data", crypted)
Console.WriteLine($"Donnée brute : {data}");
Console.WriteLine($"Donnée chiffrée : {crypted}");
HttpResponseMessage msg = await client.PostAsync(string.Concat(url, User.PATH), formContent);
Console.WriteLine(await msg.Content.ReadAsStringAsync());
But still always get this :
Donnée brute : {"id":"11", "figgoId":"30"}
Donnée chiffrée : cQJXBgVIBWLhCDG90KlyKw7zZ5093Yjunso75kwBSUPATK8=
{"error":"invalid API query", "message":""'data' is not correctly encoded for method PUT. Request for correct API KEY""}
Thus when I run several times the same input message I get different encrpyted data, so I really wonder how the server would be able to decrypt it back as it changes other time...
Last edit: 10 Feb 2022 18:23 by MagicBuzz.
10 Feb 2022 19:19 - 10 Feb 2022 19:20 #6 by kobetsu
1.
I see you declared encryption 256 by line:
$data = AesCtr::encrypt($contents, $_SERVER[1], 256);
Are you sure your PQ is using 256 ? not 128 ?
2.
Use this code as example:
string strURI = "https://xxxx/api/Delivery";
//"{\"id\":\"1090\",\"name\":\"test\"}";
strData = "XgEJZxQhrmHmPqjzqQ9YdgljeYiBAri7Y73i192XSZFLG8w"; //<--- here put your encrypted string
var content = new StringContent(strData, Encoding.UTF8, "application/json");
HttpClient httpClient = new HttpClient();
httpClient .DefaultRequestHeaders.Authorization = new AuthenticationHeaderValue("Basic", Convert.ToBase64String(Encoding.UTF8.GetBytes($"{<<user_name>>}:{<<user_password>>}")));
var result = httpClient.PutAsync(strURI, content).Result;
string resultContent = result.Content.ReadAsStringAsync().Result;
Last edit: 10 Feb 2022 19:20 by kobetsu.
