ProjeQtOr free project management software - addFieldInTextBoxForEmailTemplateItem not working with normal text editor - ProjeQtOr
22 Jun 2021 15:30 #1 by Baryhobal
It seems that the function addFieldInTextBoxForEmailTemplateItem (view/js/projeqtor.js:5756 V9.1.2) doesn't work with the normal text editor. Indeed, on line 5748, idTextBox is set to dojo.byId('template').value, but on line 5781, it tries to use setValue on idTextBox. I believe line 5748 should be var idTextBox = dojo.byId('template');
Line 5748:
var idTextBox = dojo.byId('template').value;
Line 5781:
idTextBox.setValue(newText);
Corrected line 5748:
The following user(s) said Thank You: Flou
23 Jun 2021 10:40 - 23 Jun 2021 10:50 #2 by Flou
thank you for finding and fixing a problem.
Your fixe it's right, it must replace  on ligne 5748 in view/js/projeqtor.js
by:
This correction will be available in V9.2.1.
Last edit: 23 Jun 2021 10:50 by Flou.
24 Jun 2021 12:26 #3 by Baryhobal
I just tested the fix. It seems it should even be dijit.byId and not dojo.byId
